<operator name="Root" class="Process" expanded="yes"> <operator name="CSVExampleSource" class="CSVExampleSource"> <parameter key="filename" value="C:\rapid.csv"/> </operator> <operator name="Nominal2Binominal" class="Nominal2Binominal"> </operator> <operator name="ChangeAttributeRole" class="ChangeAttributeRole"> <parameter key="name" value="ITEM"/> </operator> <operator name="Aggregation" class="Aggregation"> <list key="aggregation_attributes"> <parameter key="TID" value="sum"/> </list> </operator> <operator name="Example2AttributePivoting" class="Example2AttributePivoting"> <parameter key="group_attribute" value="TID"/> <parameter key="index_attribute" value="ITEM"/> </operator> <operator name="ResultWriter" class="ResultWriter"> <parameter key="result_file" value="C:\result16.res"/> </operator></operator>
<operator name="Root" class="Process" expanded="yes"> <operator name="CSVExampleSource" class="CSVExampleSource"> <parameter key="filename" value="C:\Documents and Settings\Administrator\Desktop\excel\rapid.csv"/> </operator> <operator name="Nominal2Binominal" class="Nominal2Binominal"> </operator> <operator name="ChangeAttributeRole" class="ChangeAttributeRole"> <parameter key="name" value="TID"/> <parameter key="target_role" value="id"/> </operator> <operator name="Aggregation" class="Aggregation"> <list key="aggregation_attributes"> <parameter key="TID" value="sum"/> </list> </operator> <operator name="Example2AttributePivoting" class="Example2AttributePivoting"> <parameter key="group_attribute" value="ITEM"/> <parameter key="index_attribute" value="TID"/> </operator> <operator name="ResultWriter" class="ResultWriter"> <parameter key="result_file" value="C:\Documents and Settings\Administrator\Desktop\answer16.res"/> </operator></operator>
<operator name="Root" class="Process" expanded="yes"> <operator name="CSVExampleSource" class="CSVExampleSource"> <parameter key="filename" value="C:\Documents and Settings\Administrator\Desktop\excel\rapid.csv"/> </operator> <operator name="Nominal2Binominal" class="Nominal2Binominal"> </operator> <operator name="ChangeAttributeRole" class="ChangeAttributeRole"> <parameter key="name" value="TID"/> <parameter key="target_role" value="id"/> </operator> <operator name="Aggregation" class="Aggregation"> <list key="aggregation_attributes"> <parameter key="TID" value="sum"/> </list> </operator> <operator name="ResultWriter" class="ResultWriter"> <parameter key="result_file" value="C:\Documents and Settings\Administrator\Desktop\answer16.res"/> </operator></operator>
<operator name="Root" class="Process" expanded="yes"> <operator name="SimpleExampleSource" class="SimpleExampleSource"> <parameter key="filename" value="C:\Dokumente und Einstellungen\Mierswa\Desktop\market_data.txt"/> <parameter key="read_attribute_names" value="true"/> </operator> <operator name="IdTagging" class="IdTagging"> </operator> <operator name="ChangeAttributeRole" class="ChangeAttributeRole"> <parameter key="name" value="id"/> </operator> <operator name="Example2AttributePivoting" class="Example2AttributePivoting"> <parameter key="group_attribute" value="TID"/> <parameter key="index_attribute" value="ITEM"/> </operator> <operator name="Numerical2Polynominal" class="Numerical2Polynominal"> </operator> <operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="yes"> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="attribute_name_regex" value="TID"/> <parameter key="invert_selection" value="true"/> <operator name="Mapping" class="Mapping"> <parameter key="attributes" value=".*"/> <list key="value_mappings"> </list> <parameter key="replace_what" value="?"/> <parameter key="replace_by" value="false"/> <parameter key="add_default_mapping" value="true"/> <parameter key="default_value" value="true"/> </operator> </operator> <operator name="FPGrowth" class="FPGrowth"> </operator></operator><operator name="Root" class="Process" expanded="yes"> <operator name="SimpleExampleSource" class="SimpleExampleSource"> <parameter key="filename" value="C:\Dokumente und Einstellungen\Mierswa\Desktop\market_data.txt"/> <parameter key="read_attribute_names" value="true"/> </operator> <operator name="IdTagging" class="IdTagging"> </operator> <operator name="ChangeAttributeRole" class="ChangeAttributeRole"> <parameter key="name" value="id"/> </operator> <operator name="Example2AttributePivoting" class="Example2AttributePivoting"> <parameter key="group_attribute" value="TID"/> <parameter key="index_attribute" value="ITEM"/> </operator> <operator name="Numerical2Polynominal" class="Numerical2Polynominal"> </operator> <operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="yes"> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="attribute_name_regex" value="TID"/> <parameter key="invert_selection" value="true"/> <operator name="Mapping" class="Mapping"> <parameter key="attributes" value=".*"/> <list key="value_mappings"> </list> <parameter key="replace_what" value="?"/> <parameter key="replace_by" value="false"/> <parameter key="add_default_mapping" value="true"/> <parameter key="default_value" value="true"/> </operator> </operator> <operator name="FPGrowth" class="FPGrowth"> </operator></operator>
