🎉Community Raffle - Win $25
Join and Win
"arabic text classification"
nabilsalhiUser: "nabilsalhi"
New Altair Community Member
Updated by Jocelyn
Hi
Is rapidmner support other languages like arabic . If yes how can i use it to classify arabic texts
Thank you
1 - 7 of 71
    landUser: "land"
    Hi,
    RapidMiner does not care about the language of the texts. All texts, that can be separated in single words, might be used to build a bag of words.
    Just use the text plugin as described in its samples.
    Greetings,
      Sebastian
    emaUser: "ema"
    Hi,
    I presonly worked with it , just add utf8 , or the word unicode in the encoding field
    Hi
    If I can use arabic text classification, why there is an english and german stemmers
    Thank you
    Mmm, a tough one, don't suppose it could be for English or German text classification? Just a wild and uninspired guess.
    emaUser: "ema"
    you  dont need to use the german or the english stemmers ,
    Rapid miner does not support arabic stemming ,
    what you can do is either use n-grams  or stem the text files outside rapidminer
    helloo
     i am beginner   can you help me please to  change  the encoding   to can work with arabic textes !
    Hi, Can you please share the sample file.
