Problem with mapping nominal -
New Altair Community Member
Updated by Jocelyn
Dear all,
I'm still struggling with the feature evaluation processing chain also described in my post from yesterday:
My questions are: 1) Is this the right way to solve this problem? and 2) How do I configure the Mapping operator to map my nominal labels to values 1..n?
Thanks a lot in advance!
<?xml version="1.0" encoding="US-ASCII"?>With NaiveBayes or Decision Trees this scheme works fine (despite the error message, see my post from yesterday), however, with LibSVMLearner I run into a problem: This operator requires numerical attributes while ClassificationPerformance requires nominal ones. That's why I added this Mapping operator.
<process version="4.3">
<operator name="Root" class="Process" expanded="yes">
<operator name="Data Source" class="ArffExampleSource">
<parameter key="data_file" value="all_subjects.arff"/>
<parameter key="id_attribute" value="id"/>
<parameter key="label_attribute" value="label"/>
</operator>
<operator name="YAGGA2" class="YAGGA2" expanded="yes">
<parameter key="use_diff" value="true"/>
<parameter key="use_max" value="true"/>
<parameter key="use_min" value="true"/>
<parameter key="use_sin" value="false"/>
<parameter key="use_square_roots" value="true"/>
<operator name="SimpleValidation" class="SimpleValidation" expanded="yes">
<parameter key="create_complete_model" value="true"/>
<operator name="OperatorChain" class="OperatorChain" expanded="yes">
<operator name="Mapping" class="Mapping">
</operator>
<operator name="LibSVMLearner" class="LibSVMLearner" breakpoints="before">
<parameter key="calculate_confidences" value="true"/>
<parameter key="svm_type" value="epsilon-SVR"/>
</operator>
</operator>
<operator name="Applier Chain" class="OperatorChain" expanded="yes">
<operator name="Test" class="ModelApplier">
<list key="application_parameters">
</list>
<parameter key="keep_model" value="true"/>
</operator>
<operator name="ClassificationPerformance" class="ClassificationPerformance">
<parameter key="keep_example_set" value="true"/>
<parameter key="root_mean_squared_error" value="true"/>
<parameter key="root_relative_squared_error" value="true"/>
<parameter key="weighted_mean_precision" value="true"/>
<parameter key="weighted_mean_recall" value="true"/>
</operator>
</operator>
</operator>
<operator name="ProcessLog" class="ProcessLog">
<parameter key="filename" value="process_log.txt"/>
<list key="log">
<parameter key="Generation" value="operator.YAGGA2.value.generation"/>
<parameter key="Recall" value="operator.ClassificationPerformance.value.weighted_mean_recall"/>
<parameter key="Precision" value="operator.ClassificationPerformance.value.weighted_mean_precision"/>
</list>
</operator>
</operator>
<operator name="AttributeWeightsWriter" class="AttributeWeightsWriter">
<parameter key="attribute_weights_file" value="svm/attribute.wgt"/>
</operator>
<operator name="PerformanceWriter" class="PerformanceWriter">
<parameter key="performance_file" value="svm/performance.per"/>
</operator>
<operator name="AttributeConstructionsWriter" class="AttributeConstructionsWriter">
<parameter key="attribute_constructions_file" value="svm/attribute.att"/>
</operator>
</operator>
</process>
1 - 3 of
31
In general it is no good idea to transform a classification task (nominal label) into a regression task (numerical label) without justification by domain knowledge
regards,
Steffen
