AttrbuteCreation IF Syntax
Hi,
I tried to make an Operator that creates a new Attribute (e.g. CLASS) that is "ACTIVE" for entries with an (numerical) activity higher than 50 and "INACTIVE" for entries with an activity below 50.
My first attempt was using the AttributeConstruction Operator, but I couldn't figre out how I make a function that distinguishes between actives and inactives.
Can anybody help me with this?
Thanks in advance.
Markus
Thanks in advance.
Markus
1 - 11 of
111
Hello again!
That works great for an active/inactive switch. But what if I want more than two categories. For example I want to distinguish between low, medium, heavy and very heavy depending on the activity. So I have boundaries for each category. Do I have to nest some if clauses, is there a way to program multiple switches or is there a special operator that does the classification for me.
As always thx in advance.
Markus
Markus
Hi Sebastian,
So I figures out that this code will do the classification I want:
So how do I classify according to one column and just change this one column without removing all others?
Best wishes,
Markus
I put a AttributeSubsetPreprocessing Operator in front, because I don't want to cluster all (numeric) columns. This works fine, but actually it removes all other column although the option for "keep subset only" is not checked.
<operator name="Classify data" class="OperatorChain" expanded="yes">
<operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="yes">
<parameter key="attribute_name_regex" value="AA"/>
<parameter key="condition_class" value="attribute_name_filter"/>
<parameter key="deliver_inner_results" value="true"/>
<parameter key="parameter_string" value="CSA"/>
<operator name="UserBasedDiscretization" class="UserBasedDiscretization" breakpoints="after">
<list key="classes">
<parameter key="low" value="4.5"/>
<parameter key="medium" value="7.5"/>
</list>
<parameter key="return_preprocessing_model" value="true"/>
</operator>
</operator>
Best wishes,
Markus
Now I am almost there where I want to be. I am now clustering my data into different cluster by a user-defined criterion. What I finally wan is to perform a Descicion tree or Rule learner and cluster according to these rules.
Again I searched for an appropriate Operator but I couldn't find it.
Best wishes,
Markus
Best wishes,
Markus
But a decision tree does not create an output column similar to a cluster algorithm, isn't it? I want that the Decision tree assignes a id for each group of examples according to the found rules.
Cubist (by Rulequest) is doing something like this (at least as far as I understand) and I want to implement this with RM.
Best wishes,
Markus
Best wishes,
Markus
the AttributeConstruction Operator is the right tool to achieve this. Here's how it works: Greetings,
Sebastian
