🎉Community Raffle - Win $25
Join and Win
ExampleFilter
TillUser: "Till"
New Altair Community Member
Updated by Jocelyn
Hi there,
I want to link several conditions concerning two different attributes in the exampleFilter.
Example:
filter out the examples where A > 5 AND B = 'string1' OR B = 'string2'
The problem is that I can't use the exampleFilter successively, because in the case B = 'string2' A is zero.
Does anybody have an idea about how to handle this?
Thanks!
1 - 2 of 21
    User: "land"
    HI,
    you could realise the or connection by using an IOMultiplier to duplicate your exampleSet. Then filter successivly the and conditions and switch with IOSelector to the second exampleSet. Filter there B = String2 and then merge both exampleSet with ExampleSetMerge.
    Wasn't that easy?  :)
    Greetings,
      Sebastian
    TillUser: "Till"
    OP
    Thanks Sebastian!
