jave Heap Space
Hai
I have some doubts to ask from you.
When i run my below code in rapid miner i get the error heap space problem.
i have 2GB RAM only and my data set is like 2 regular attributes, 50000 example.
DO i have any other changes to be done to get the result like improve my code / do I need to upgrade my RAM .
thanks
Priyan
<operator name="Root" class="Process" expanded="yes">
<operator name="CSVExampleSource" class="CSVExampleSource">
<parameter key="filename" value="C:\b9.csv"/>
</operator>
<operator name="Numerical2Polynominal" class="Numerical2Polynominal">
</operator>
<operator name="Aggregation" class="Aggregation">
<list key="aggregation_attributes">
<parameter key="item" value="count"/>
</list>
<parameter key="group_by_attributes" value="tid|item"/>
</operator>
<operator name="Example2AttributePivoting" class="Example2AttributePivoting">
<parameter key="group_attribute" value="tid"/>
<parameter key="index_attribute" value="item"/>
</operator>
<operator name="ChangeAttributeRole" class="ChangeAttributeRole">
<parameter key="name" value="tid"/>
</operator>
<operator name="UserBasedDiscretization" class="UserBasedDiscretization">
<list key="classes">
<parameter key="yes" value="1.0"/>
<parameter key="no" value="0.0"/>
</list>
</operator>
<operator name="FPGrowth" class="FPGrowth">
<parameter key="min_support" value="0.2"/>
</operator>
<operator name="AssociationRuleGenerator" class="AssociationRuleGenerator">
<parameter key="keep_frequent_item_sets" value="true"/>
<parameter key="min_confidence" value="0.4"/>
</operator>
<operator name="ResultWriter" class="ResultWriter">
<parameter key="result_file" value="C:\Documents and Settings\svpriyan\Desktop\7to13res.res"/>
</operator>
</operator>
thanks
Priyan
