🎉Community Raffle - Win $25
Join and Win
Compute rank within subgroups
User: "keith"
New Altair Community Member
Updated by Jocelyn
Is there an operator that will compute the rank of each row according to some attribute value?  If so, is it possible to do so for subgroups within an example set?
e.g.  Compute RANK based on VALUE within each GRP group
GRP ID   VALUE   RANK
1  a    5      1
1  b    10      2
1  c    20      3
2  d    7      1
2  e    50      2
2  f    51      3
Thanks.
Keith
1 - 3 of 31
    User: "IngoRM"
    Hi Keith,
    not a single operator but you could use a combination of several operators (I am talking about the upcoming release 4.3 here):
    - value iterator to iterate over the groups
    - example filter to filter out only the current group
    - sorting to build the rank
    - id taggin to give numbers for the ranks
    - io retriever to retrieve last result
    - example set merge to merge the current group ranking with the last one (retrieved)
    - io storer to store the current result again in the store
    It's will be a nice process for such a "simple" task  ;)
    Cheers,
    Ingo
    User: "jan87"
    Hello,
    I 've got exactly the same problem like Keith.
    Is there meanwhile any simpler solution to solve this?
    If not: Would you mind to post an example process with the described solution?
    Thanks a lot,
    Jan
    User: "MariusHelf"
    Well, now it's doable with only 5 operators oO
    Here you go!
    Best regards, Marius
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.3.000">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process">
        <process expanded="true" height="549" width="701">
          <operator activated="true" class="subprocess" compatibility="5.3.000" expanded="true" height="76" name="Generate Data (3)" width="90" x="45" y="30">
            <process expanded="true" height="531" width="550">
              <operator activated="true" class="generate_data" compatibility="5.3.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30">
                <parameter key="number_examples" value="5"/>
                <parameter key="number_of_attributes" value="1"/>
              </operator>
              <operator activated="true" class="generate_attributes" compatibility="5.3.000" expanded="true" height="76" name="Generate Attributes" width="90" x="179" y="30">
                <list key="function_descriptions">
                  <parameter key="grp" value="&quot;1&quot;"/>
                </list>
              </operator>
              <operator activated="true" class="generate_data" compatibility="5.3.000" expanded="true" height="60" name="Generate Data (2)" width="90" x="45" y="120">
                <parameter key="number_examples" value="4"/>
              </operator>
              <operator activated="true" class="generate_attributes" compatibility="5.3.000" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="179" y="120">
                  <parameter key="grp" value="&quot;2&quot;"/>
                </list>
              </operator>
              <operator activated="true" class="append" compatibility="5.3.000" expanded="true" height="94" name="Append" width="90" x="313" y="75"/>
              <connect from_op="Generate Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
              <connect from_op="Generate Attributes" from_port="example set output" to_op="Append" to_port="example set 1"/>
              <connect from_op="Generate Data (2)" from_port="output" to_op="Generate Attributes (2)" to_port="example set input"/>
              <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Append" to_port="example set 2"/>
              <connect from_op="Append" from_port="merged set" to_port="out 1"/>
              <portSpacing port="source_in 1" spacing="0"/>
              <portSpacing port="sink_out 1" spacing="0"/>
              <portSpacing port="sink_out 2" spacing="0"/>
            </process>
          </operator>
          <operator activated="true" class="loop_values" compatibility="5.3.000" expanded="true" height="76" name="Loop Values" width="90" x="179" y="30">
            <parameter key="attribute" value="grp"/>
            <parameter key="iteration_macro" value="grp"/>
            <process expanded="true" height="549" width="433">
              <operator activated="true" class="filter_examples" compatibility="5.3.000" expanded="true" height="76" name="Filter Examples" width="90" x="45" y="30">
                <parameter key="condition_class" value="attribute_value_filter"/>
                <parameter key="parameter_string" value="grp=%{grp}"/>
              </operator>
              <operator activated="true" class="sort" compatibility="5.3.000" expanded="true" height="76" name="Sort" width="90" x="179" y="30">
                <parameter key="attribute_name" value="att1"/>
              </operator>
              <operator activated="true" class="generate_id" compatibility="5.3.000" expanded="true" height="76" name="Generate ID" width="90" x="313" y="30"/>
              <connect from_port="example set" to_op="Filter Examples" to_port="example set input"/>
              <connect from_op="Filter Examples" from_port="example set output" to_op="Sort" to_port="example set input"/>
              <connect from_op="Sort" from_port="example set output" to_op="Generate ID" to_port="example set input"/>
              <connect from_op="Generate ID" from_port="example set output" to_port="out 1"/>
              <portSpacing port="source_example set" spacing="0"/>
            </process>
          </operator>
          <operator activated="true" class="append" compatibility="5.3.000" expanded="true" height="76" name="Append (2)" width="90" x="313" y="30"/>
          <connect from_op="Generate Data (3)" from_port="out 1" to_op="Loop Values" to_port="example set"/>
          <connect from_op="Loop Values" from_port="out 1" to_op="Append (2)" to_port="example set 1"/>
          <connect from_op="Append (2)" from_port="merged set" to_port="result 1"/>
        </process>
      </operator>
    </process>
