Altair RISE
Nominate Yourself Now!
"RM gui does not work with Java 6 Update 10"
User: "Username"
New Altair Community Member
Updated by Jocelyn
Hi,
Rapid Miner does not work properly with the latest Java version (Java 6 Update 10), The parameter panel is broken with operators that have certain paramter types (my guess). I can see hundreds of lines of the following:
I have this problem e.g. with the ProcessLog operator and many other operators. There's no problem with Java 6 Update 7.
1 - 3 of 31
    User: "land"
    Hi,
    "OS independent they said, they did not say: Version indepenent"
    Same error here, if I update to the newest version.
    But there is a simple solution: Use Update 7 until we have fixed this. We're working on it. But I don't know whats going on there and why this fails now.
    Greetings,
      Sebastian
    User: "Username"
    OP
    I just wanted to point out this problem. For my processes I'm still using U7.  ;)
    Maybe the Swing threading violations in RM are the reason for this problem.
    User: "land"
    Hi,
    the bug has been fixed and is available in the current CVS versions.
    By the way: It hasn't been the thread violations, instead the java people have changed some underlying code, causing a method call loop "a calls b, b calls a". That's why the stack did overflow.
    Greetings,
      Sebastian
