🎉Community Raffle - Win $25
Join and Win
"C parser for decision trees"
User: "Legacy User"
New Altair Community Member
Updated by Jocelyn
Hi,
I'm generating decision trees which are constructed from a CSV file. The content
of the file (examples for my training set) looks as follows:
a  b  c  label
1  3  5  0
3  5  2  1
The decision tree represents a classification that is used to steer
a particular routine within a C++ program. The column notations (a,b,c)
are real variables within the routine. Up to now, I had to translate
the decision tree by hand into equivalent if-then-else C++ statements.
This is very tedious for larger trees. Moreover, I would like to use the
leave-one-one cross-validation for which I have to generate as many
decision trees as many examples I have. This cannot be done manually
in an acceptable amount of time.
Do you know a way how to automatically translate RapidMiner's decision
trees into C++ code like
if( a < 10 ) {
  if( b > 20 )
    return true;
  else if(  c < 100 )
  return false;
Maybe there is a  parser plug-in for that.
Thank you for your help.
Regards,
Tim
1 - 1 of 11
    User: "IngoRM"
    Hi Tim,
    I am sorry but I am not aware of any implementation of that. Maybe somebody else?
    Cheers,
    Ingo
