Altair RISE
Nominate Yourself Now!
W-Logistic and EqualLabelWeighting
User: "Username"
New Altair Community Member
Updated by Jocelyn
Hi,
the W-Logistic operator throws an exception: "sum of weight of instances less than 1". I'm using the EqualLabelWeighting operator for assigning weights to examples. Shouldn't the summed up weights of all exampes be 1?
Thanks
1 - 2 of 21
    User: "TobiasMalbrecht"
    Hi,
    yes, in principal the weights created by the [tt]EqualLabelWeighting[/tt] operator should sum to 1 with the default parameter values. Did you check if the error occurs also when you set the [tt]total_weight[/tt] parameter to value greater than 1? Perhaps the weights do not sum exactly to 1 because of rounding errors?
    Regards,
    Tobias
    User: "Username"
    OP
    Tobias Malbrecht wrote:
    Hi,
    Regards,
    Tobias
    I tried  [tt]total_weight = 2[/tt] without any problems. I guess you're right with the rounding errors.
