Buolding RapidMiner Icons
teflondt
teflondt New Altair Community Member
edited November 2024 in Community Q&A
I am anew user to rapid miner i however use Netbeans when i build rapid miner and delete the rapidminer.jar in the lib directory i get some an error indicating that I suspect that what is in the source  is different from what is in the library can anyone clarify to me why i cant run without /lib/rapidminer.jar when i replace it with the one i will have created it fails to run.
Answers
  • TobiasMalbrecht
    TobiasMalbrecht New Altair Community Member
    Hi,
    unfortunately I do not yet see what is the problem here. Could you please post the exact error message?!
    Thanks,
    Tobias
  • land
    land New Altair Community Member
    Hi,
    did you run the Ant target "copy-resources" of the build.xml? I'm an eclipse user so I can't give you much advise how this could be performed with Netbeans, but there will probably some way within netbeans.
    Greetings,
      Sebastian
Welcome!
Welcome!
