🎉Community Raffle - Win $25
Join and Win
Can't get PSOWeighting to work
User: "keith"
New Altair Community Member
Updated by Jocelyn
I've been playing around with PSOWeighting, and must be doing something wrong, because however I run it, it is returning weights of zero for every attribute.
Here's the fragment of the operator chain:
        <operator name="PSOWeighting" class="PSOWeighting" breakpoints="after" expanded="yes">
            <operator name="XValidation (2)" class="XValidation" expanded="yes">
                <parameter key="number_of_validations" value="5"/>
                <parameter key="sampling_type" value="shuffled sampling"/>
                <operator name="NearestNeighbors" class="NearestNeighbors">
                    <parameter key="k" value="2"/>
                    <parameter key="keep_example_set" value="true"/>
                    <parameter key="weighted_vote" value="true"/>
                </operator>
                <operator name="OperatorChain (2)" class="OperatorChain" expanded="yes">
                    <operator name="ModelApplier (2)" class="ModelApplier">
                        <list key="application_parameters">
                        </list>
                    </operator>
                    <operator name="Performance (2)" class="Performance">
                    </operator>
                </operator>
            </operator>
        </operator>
My data has both numerical and polynominal attributes, and a numerical label.
I was originally running the chain with EvolutionaryWeighting (after a suggestion I found on this board), and it successfully returns non-identical weights.  Replacing the operator with PSOWeighting, and using the default parameters, produces all zeros.
I saw no errors in the logs, and looking at the docs there don't appear to be any missing inputs.  What am I missing?
Thanks, as always.
Keith
1 - 1 of 11
    User: "keith"
    OP
    Since no one has had anything to say here, is there a working example of PSOWeighting that I could look at and learn from?
