I've been playing around with PSOWeighting, and must be doing something wrong, because however I run it, it is returning weights of zero for every attribute.
Here's the fragment of the operator chain:
<operator name="PSOWeighting" class="PSOWeighting" breakpoints="after" expanded="yes">
<operator name="XValidation (2)" class="XValidation" expanded="yes">
<parameter key="number_of_validations" value="5"/>
<parameter key="sampling_type" value="shuffled sampling"/>
<operator name="NearestNeighbors" class="NearestNeighbors">
<parameter key="k" value="2"/>
<parameter key="keep_example_set" value="true"/>
<parameter key="weighted_vote" value="true"/>
<operator name="OperatorChain (2)" class="OperatorChain" expanded="yes">
<operator name="ModelApplier (2)" class="ModelApplier">
<list key="application_parameters">
</list>
<operator name="Performance (2)" class="Performance">
My data has both numerical and polynominal attributes, and a numerical label.
I was originally running the chain with EvolutionaryWeighting (after a suggestion I found on this board), and it successfully returns non-identical weights. Replacing the operator with PSOWeighting, and using the default parameters, produces all zeros.
I saw no errors in the logs, and looking at the docs there don't appear to be any missing inputs. What am I missing?
Thanks, as always.
Keith
