1 - 6 of
61
Hi,
well if you set up the [tt]DatabaseExampleSource[/tt] operator properly you already finished the initial part of every Data Mining process which is to load the data. What operators you need to put into your process after the input operator depends on what you intend to do, transform your data, learn a prediction model, etc. There are numerous operators since there are innumerable data mining tasks. To summarize, unless you do not tell us what you intend to do with your data we unfortunately are not able to tell you how to set up a process for your task in RapidMiner. Sorry, but you have to be really more specific!
Cheers,
Tobias
Cheers,
Tobias
Hello afandiphd
I really really suggest to....
- do the tutorial (RapidMinerGUI->Help->RapidMiner Tutorial)
- download the tutorial.pdf from here. Beside further explanations all operators are described in this document
Then: If you still have any more questions, feel free to come back and ask
greetings
Steffen
greetings
Steffen
Hi afandiphd,
additionally, I would like to recommend to attend one of our introductary data mining & RapidMiner courses (http://rapid-i.com/content/view/7/95/lang,en/) ...
But seriously, if you want to learn a classification model, the first steps are to mark an attribute as a label by applying the [tt]ChangeAttributeRole[/tt] operator. After that, you may try a learner such as a [tt]DecisionTree[/tt], the [tt]LibSVM[/tt], [tt]NaiveBayes[/tt] .. which learner you actually can (and might want to) use depends once again on your analysis goals as well as on your data!
Cheers,
Tobias
Cheers,
Tobias
Hope this helps.
Keith
