🎉Community Raffle - Win $25
Join and Win
"XYValidation Model Profiling - Lift and Variable importance"
User: "alvinc"
New Altair Community Member
Updated by Jocelyn
Hi all,
I would like to profile a cross-fold validation model using lift chart and variable importance. I haven't had luck figuring how to do so and hope I may get some help on the following -
- How do I generate betas coefficients or variable influence for algorithms such as SVM, similar to the betas in Logistic Regression?
- Is it possible to output standardized betas in Logistic Regression and other algorithms?
- How do I use the lift chart node? I haven't had success placing the lift chart node after model applier node, a chart pops up with the message : "No data points available (yet)"
- Is it possible to output a decile lift table?
Thanks in advance for your guidance!
Kind regards,
Alvin
1 - 1 of 11
    User: "IngoRM"
    Hi,
    As far as I know thereare no betas for SVM. At least I have never noticed somebody has calculated something like that. And about variable influence for SVM: the coefficients for the hyperplane (w-values) can directly be read as measure of importance. Beside that you could have a look into the group "Preprocessing" - "Attributes" - "Weighting" which contain about 20 different variable influence calculations including those for SVM, info gain for trees, Relief etc.
    They already are output of the logistic regression? And as far as I know, it is not possible to calculate those "beta"-values for other algorithms. But if you are able to explain the algorithm we could of course integrate something like that.
    Try it before. Here is a setup inside of a cross validation:
    <operator name="Root" class="Process" expanded="yes">
        <operator name="ExampleSetGenerator" class="ExampleSetGenerator">
            <parameter key="target_function" value="sum classification"/>
        </operator>
        <operator name="XValidation" class="XValidation" expanded="yes">
            <operator name="MyKLRLearner" class="MyKLRLearner">
            </operator>
            <operator name="OperatorChain" class="OperatorChain" expanded="yes">
                <operator name="LiftChart" class="LiftChart">
                </operator>
                <operator name="ModelApplier" class="ModelApplier">
                    <list key="application_parameters">
                    </list>
                    <parameter key="keep_model" value="true"/>
                </operator>
                <operator name="Performance" class="Performance">
                </operator>
            </operator>
        </operator>
    </operator>
    Currently not, sorry.
    Cheers,
    Ingo
