Keep original attributes and ignore attributes
New Altair Community Member
Updated by Jocelyn
Please add control whether the operators remove the original columns from the example set.
For example , in experiment ExampleSource-Normalization-PrincipalComponentGenerator, I would like to click some checkbox and see in the output all the columns:
original attributes, z-transformed attributes and PCs - all in one table.
Also, add an ability to mark a column "inactive" or "pass-thru", so that is shows in the example set, but is ignored by the operators, like the id type does now.
Thanks!
Thanks!
