🎉Community Raffle - Win $25
Join and Win
4.2 DatabaseExampleSource problem
haddockUser: "haddock"
New Altair Community Member
Updated by Jocelyn
Hi!
I've just upgraded to 4.2 and find that a DatabaseExampleSource that worked fine under 4.1 now produces the following error..
P Jul 16, 2008 2:43:53 PM: [Fatal] UserError occured in 1st application of DatabaseExampleSource  (DatabaseExampleSource)
P Jul 16, 2008 2:43:53 PM: [Fatal] Process failed: Database error occured: The fetch size cannot be negative.
Furthermore if I use the configuration wizard no tables get picked up. I've tried both the MS and JTDS  SQL drivers and get the same result. Does anybody know what causes this behaviour?
1 - 7 of 71
    alxUser: "alx"
    Which database are you using?
    I hit the same problem with PostgreSQL today. Obviously, a MySQL specific hack leaked into the DatabaseHandler class. The fetch size is set to Integer.MIN_VALUE unconditionally. However, this is a very MySQL specific way to tell the JDBC driver not to fetch the entire result set and I would suspect DatabaseExampleSource to break on anything but MySQL.
    OP
    Hi Aix,
    I'm using MS SQL 2005  :( All very strange...
    IngoRMUser: "IngoRM"
    Yip. This accidentally slipped in - working on MySQL most of our time and somebody (probably myself) accidentally checked in this hack. We are currently working on a workaround and will release it as soon as possible. Sorry for the inconvenience.
    Cheers,
    Ingo
    OP
    Thanks Ingo and Aix, another bout of sanity doubting avoided  ;D
    Hi,
    we just exchanged the files of the 4.2 release. Please download the release again from SourceForge (links are available on our web site - just use the normal download links).
    Sorry again for the inconvenience.
    Cheers,
    Ingo
    OP
    NIce one Ingo - all runs fine now. Many thanks for such a quick remake.
    You are welcom. And thanks for the response - good to know that it works on at least one another system  ;)
    Cheers,
    Ingo
