Apply Numeric2Polynominal (or other preprocessing operators) on feature subsets
Hi,
I know that the operator Numeric2Polynominal maps all attributes' numeric values to the corresponding nominal values. If I understood correctly, it's only the attributes' values that are mapped, and not the label (whose numerical value is to be predicted).
Is there a way (or an operator) to map only the numeric values of some attributes to the corresponding nominal values? I would actually need it for all but one attribute.
Thanks,
Geo
Thanks,
Geo
1 - 1 of
11
yes, for this purpose the operator "AttributeSubsetPreprocessing" can be used. The attributes on which the inner operators should be applied can be defined via regular expressions. This example applies a discretization on all attributes but on attribute "att3": Cheers,
Ingo
