Parametrized Rectangular Coil Model
User: "ChristophM"
Altair Employee
Updated by ChristophM
Overview
CADFEKO template for a parametrized coil model. Parameters are described in the attached pdf
Pre-Requisite
Version: CADFEKO2022.0
Usage/Installation Instructions
Open cfx-file in CADFEKO and adapt coil parameter:
- R1: "Radius" of squared loop
- R2: Radius of fillet
- H: Height
- N: Number of turns
1 - 2 of 21
    User: "AKH"
    Altair Community Member
    Updated by AKH
    Hi Christoph Maeurer,
    Can you share me the further details of the rectangular coil which will help me the inductance computation in the flux2D & flux3D. Which will further help in simulating the Ironless linear motor.
    Thanks,
    Akil Kumar H
    +917846021264
    User: "ChristophM"
    Altair Employee
    OP
    Hi Akil Kumar,
    the model ist parametrized in CADFEKO. When you want to use it in an other tool (e.g. Flux) you can export the model from CADFEKO to a CAD format (e.g. Parasolid) and import it into the tool of your choice. Of course you will loose the parametrization.
    Hope this helps.
    Kind Regards
    Christoph
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
