3D Bolt Generation Macro
Overview
Generate a 3D meshed bolt from a user inputs like thread size, thread length , offset distance etc. The generated mesh has node to node contact between the bolt and hole threads. Useful for bolt failure analysis.
Usage/Installation Instructions
1) Launch the script "3d-bolt-builder.tcl"
2) Select and enter the dimensions
3) Click Generate, this will create bolt and import the same in current HM session.
Functionality
Model/Analysis
Subfunctionality
Morphing
1 - 3 of
31
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
Hi
I need to create bolts using your script. I am unable to lunch your script. Do I have to open script in some software.
Thanks
Mirza S Baig
