🎉Community Raffle - Win $25
Join and Win
Altair Inspire® Challenge #3: 3D printed Structural Steel Connection Design
User: "Matthew_Sauer1"
Altair Employee
Updated by Matthew_Sauer1
Structural Steel Connections often require carefully designed components to safely transfer loads to the ground.  In this challenge we will design a 3D Printed Structural Steel Connector to transfer loads between a set of structural steel members to the ground.  The design must be such that it can accommodate bolted or welded connections to connect to the Structural Steel Components, and the goal of the design is to minimize weight while ensuring the load transfer to the ground occurs without plastic deformation.  The attached STMOD file can be a starting point.  It contains a sample design space, loads, and supports.  Feel free to adjust the design space, and optimization settings (lattice optimization) to your preferences.
Level: Medium
Product Required: Inspire
The solution can be attached in the comment section of this post. The desired output format is a JPG or PNG showing your optimized design.
The solution to Challenge "Cycling Shoe Cleat Design" can be found Here
If you would like to solve more challenges and get regular challenge release updates, Subscribe to the Altair Community Challenge forum
