🎉Community Raffle - Win $25
Join and Win
Composite Panel Optimization
Hi,
I have a laminate with 10 plies , and the deflection output is 5 mm.
In optimization process i want to increase deflection as 10 mm , since 10 mm is allowable deflection.
My constraints are : Plies thickness should not change,
I want to decrease number of plies to reduce laminate thickness and stiffness.
1 - 3 of 31
