Altair RISE
Nominate Yourself Now!
Minimizing internal strain energy
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I know how to define an output block to get the internal strain energy per unit volume within HyperWorks, and how to define custom objective function equations using the dequation button, but can't seem to call the internal strain energy, since I can't figure out how to define it as a response in HyperMesh. Is this feature supported in HyperMesh?
1 - 5 of 51
    Altair Employee
    OP
    @8bt39
    could you define your optimization problem?
    Compliance is a measure of strain energy, You can use compliance as a response.
    Altair Employee
    OP
    Compliance is a measure of strain energy, and for static structural problems, they are equivalent, but when accounting for thermal stresses from temperature change, most of the literature suggests that compliance does a poor job of representing the energy stored within the structure.
    Altair Employee
    OP
    @8bt39
    Okay, I will check if there is any workaround to incorporate strain energy as a response.
    Altair Employee
    OP
    Is any answer found for this question guys?
    Altair Employee
    OP
    Hi @frzti
    Try with THERMAL compliance (regular structural compliance) and check if this helps.
