hyperworks desktop is not installing
Hi i am trying to install hyperworks student edition. I am trying to download hyperworks(blue icon) after downloading and installation i cannot see the hyperworks instead hypermesh is popping up all the times. I tried installing and downloading the file multiple times but it turned to be unsuccessful. I am able to see hyperworks desktop(blue icon) file is present in the installation directory even when I try to open it is getting redirected to hypermess(red icon). Is there anyone who faced this problem earlier or is there anyone that knows solution for this?
Hello,
I am a little confused by your question. But let me try to clear something up.
Hyperworks is Altair's whole suite of simulation tools.
https://altair.com/altair-hyperworks
Hypermesh is a pre-processing software under that umbrella.
I am assuming you want Hypermesh installed, which sounds like what you have.
Hi jason thanks for the reply, yes I have seen this note of 2023 release. I am attaching a photo of the application that I want, it is the second application that you can see in the photo. I am having 5th application all the time which I do not want to use.
That is the Legacy version and should no longer be available starting with 2023
Please refer to the following landing page
So that means i cannot use legacy version anymore? and Altair has stopped users from using legacy version?
Correct. 2022.3 is the last version of legacy available.
Thank you so much. I tried installing it in the morning and it worked too except for the fact that it couldn't run optistruct. Is there any way to use it?
Did you download optistruct?
I didn't tried it but do you think it can work?? Theoritically it should if I am not wrong? I got tired of installing and uninstalling multiple times.
Hypermesh is the preprocessor. You need to install Optistruct as well to run optistruct.
I will try it thank you so much I really appreciate the patience for replying. once again thank you.
You are very welcome.
take care and have a good week.
Hello,
