BLDC with delta winding connection
I'm trying to simulate the power and control circuit for a BLDC motor.
The problem is that the motor that I will use has the coils connected in delta. The block provided in the software has Y connections.
Is there a block with delta connections or any transformation that I can do on the original motor parameters to adapt to the block available for simulation?
1 - 1 of
11
Please create a support request at
Contact Support
And provide the required information, our developer may send a customized model block to you.
