I'm trying to simulate the power and control circuit for a BLDC motor.
The problem is that the motor that I will use has the coils connected in delta. The block provided in the software has Y connections.
Is there a block with delta connections or any transformation that I can do on the original motor parameters to adapt to the block available for simulation?
