Altair RISE
Nominate Yourself Now!
Sequential Simulation not Continuing
User: "d_con13"
Altair Community Member
Updated by d_con13
I have a model in which I want to start with a fixed joint to maintain initial geometry, and then release after a short time in motion. Per MV-1051, I have added a template file as below, however when I save and run (and can confirm that the joints activate and deactivate in the run log, see italicized log snippet), the second half of the simulation does not appear to run and jumps right to the stop (see italicized snippet). I am not sure what is causing the second part of the sequence not to proceed - any help would be greatly appreciated.
<Deactivate
    element_type = "JOINT"
    element_id   = "301001"
<Simulate
analysis_type      = "Transient"
end_time       = ".05"
print_interval = "0.001"
<Deactivate
    element_id   = "{j_init_fix.idstring}"
<Activate
<Simulate
end_time       = "5."
<Stop/>
 Starting kinematic analysis...
 Time=1.000E-03; H=1.000E-03 [Max Phi=2.087E-11]
 Time=5.000E-03; H=1.000E-03 [Max Phi=2.087E-11]
 Time=1.000E-02; H=1.000E-03 [Max Phi=2.087E-11]
 Time=1.500E-02; H=1.000E-03 [Max Phi=2.087E-11]
 Time=2.000E-02; H=1.000E-03 [Max Phi=2.087E-11]
 Time=2.500E-02; H=1.000E-03 [Max Phi=2.087E-11]
 Time=3.000E-02; H=1.000E-03 [Max Phi=2.087E-11]
 Time=3.500E-02; H=1.000E-03 [Max Phi=2.087E-11]
 Time=4.000E-02; H=1.000E-03 [Max Phi=2.087E-11]
 Time=4.500E-02; H=1.000E-03 [Max Phi=2.087E-11]
 Time=5.000E-02; H=1.000E-03 [Max Phi=2.087E-11]
 CUMULATIVE COMPUTE TIME INFORMATION
 Preprocessing Model      : 4.400E-02 sec
 Core Analysis            : 1.900E-02 sec
 Postprocessing/Messaging : 3.300E-02 sec
 Total Elapsed Time       : 9.600E-02 sec
INPUT:
 [actuator_control_DPC.xml]
OUTPUT:
 [actuator_control_DPC.mrf]
 [actuator_control_DPC.log]
TRANSIENT SIMULATION COMPLETED
 Deactivate JOINT/301012
 Activate JOINT/301001
Execution terminated by STOP command.
1 - 2 of 21
    User: "Praful"
    Altair Employee
    Updated by Praful
    Hello @d_con13
    It is hard to figure out a reason why that does not work without looking at the model? Is it possible to share the model ?
    What type of joint is "301001" ? If its an inplane or planar joint, you may have to use the keyword "JPRIM".
    Regards
    Praful
    User: "d_con13"
    OP
    Updated by d_con13
    Unfortunately I don't think I can share the rest of the model, but it is a relatively simple crank-slider type assembly consisting of two bars, one on a rotating base point and the other end of the linkage in a translational joint. I am trying to lock the base pivot, Joint 301001 for the initial motion and then release (Joint 301001 is a revolute joint)
