Incremental output of GPFORCE or SPCFORCE in NLSTAT simulation
Hi,
I'm running a NLSTAT (quasi static simulation) analysis with geometric and material nonlinearities with large displacements. I need Reaction forces of all incremenets in a specific spc node to get the FORCE/TIME STEP graph. I read before that this output of GPFORCE or SPCFORCE is not supported in older versions. What about the latest one? Is there something I have missed? Also what is your suggestion on alternative, if that output is not supported? Dynamic implicit simulation?
Thanks for your answer!
1 - 7 of
71
- PARAM>EXPERTNL>NO
- NLADAPT>DIRECT>YES
- DTmax=DTmin (NLADAPT)
Hi,
Increment are automatically adjusted by default (PARAM>EXPERTNL>AUTO). The increment can be fixed using either:
Hi @mihabreznik
This feature should be available with NLOUT option and HyperWorks update 14.210.
Please give it a try
/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
