Altair RISE
Nominate Yourself Now!
TOTAL ENERGY PLOT
User: "harshitpuri"
Altair Community Member
Updated by harshitpuri
i'm trying to carry out a drop test with a body having initial velocity,
as soon as the the specimen impacts the ground the internal enrgy rises but kinetic energy of model is not reducing in that manner2.PNG
there is overall very high rise in total energy although the body is in proper contact with ground
total energy curve isn't remain constant or stable as soon as body touches ground.
1 - 19 of 191
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi Harshit,
    Check what is the contributing more to the total energy. Check whether the contact energy is within the limit or high also check the hour glass energy.
    If the problem is with hour glass energy, change the element formulation to fully integrated.
    If the problem is with contact energy, try changing the contact parameters.
    User: "harshitpuri"
    OP
    Contact Energy is very less.
    Hourglass is under 10%limit of total
    here is complete plot of graphs<?xml version="1.0" encoding="UTF-8"?>whole graph.PNG
    as you can see the internal energy absorbed by the structure is way more than total/ kinetic energy when impact happened, the impact happened at .02 sec from where kinetic energy starts declining.
    the friction co-efficient is .2 its a planar rwall.
    Somewhere from graph i infer that the kinetic energy of body is not decreasing as the slope of total energy almost remains constant before and after impact.
    Altair Employee
    Models with initial KE (initial velocity) will have large Total Energy value but it should be somewhat constant throughout. But when the Total Energy varies significantly there is some major error in the model created or defined.
    User: "harshitpuri"
    OP
    yes , even i think so, but i failed to identify as such , moreover i have recreated BCs many time but cant get rid of it.  what can be preferred checks for same?
    Altair Employee
    Can you upload the model file?
    User: "harshitpuri"
    OP
    yes,
    i'm attaching the.rad file
    User: "harshitpuri"
    OP
    any observation Sir?
    Altair Employee
    Try running it with the boundary condition INITIAL VELOCITY (/INIVEL). You have imposed /INIVEL/AXIS.
    Try with initial velocity and see the output result
    User: "harshitpuri"
    OP
    the body is freely falling after losing stability from a height from a tilted platform to ground 800 mm below the tilting axis in heightCapture.PNG
    I have calculated angular velocity just above ground using parallel axis theorem and imposed same.
    So imposed velocity may not apply real scenario.
    User: "RAMGANESH"
    Updated by RAMGANESH
    Dear Harshitpuri,
    What about the gravity you have applied to the model?
    Altair Employee
    Hi Harshit,
    For angular velocity calculations, what mass have you considered?
    is it Kerb/curb mass of the vehicle, if yes, is it same as the mass of the FE model?
    Since I am using 12.0 i am not able to open your model file, what is the material model have you used?
    Any contacts, 1D elements?
    User: "harshitpuri"
    OP
    Hello Prakash,
    Yes, i have taken the kerb weight for the calculation of angular velocity i have taken Moment of Inertia (xx) axis of rotation about  abt c.g
    and then used formula .5*(I+mr^2)= mh(hdiff)
    r is distance of cg from rotation axis
    hdiff  is height diffrence (pre and post rotation to ground from point of unstability)
    m is kerb weight of vehicle
    there's no other mass in whole model even the tilting axis weighs less than a k.g (the mass of Fe model and bus are same 8.3 ton)
    the angular velocity is around 2rad/s which is justified as i have carried out simulations on these values for the bus rollover analysis earlier.
    contacts - all nodes are slave to rigid wall and have tried simulation with and without other contacts.
    No 1 d elements in model
    rigid and admass elements are present and they are assigned with boundary Condtion.
    Dear Harshitpuri,
    Hello Ram,
    Yes gravity is applied to the whole bus using curve except for stopper /snug
    x 0
    y -9810
    x 1
    y -9810
    using grav load card
    direction
    Z is direction of height (+ve Upwards)
    Altair Employee
    Hi Harshit,
    Can you export the model to RADIOSS 110 format and share the same to my dropbox link (in my signature below)?
    User: "RAMGANESH"
    Hi Harshit,
    Can you upload the model in format as prakash mentioned above?
    User: "harshitpuri"
    OP
    yes ram here it is
    prakash i have uploaded the same in your dropbox
    User: "RAMGANESH"
    Dear Harshit,
    1.In your model there are free nodes,
    2. In rigid elements , Rbody ID is different from master ID
    3. what is that component in the name 1?? It contains admas (mass) but you have not updated it as Rbody/admas in the component collector.
    4.Check the model for intersection & penetration.
    Altair Employee
    I can see few modelling errors. There are penetrations. Please correct them.
    Try to plot energy balance curve for individual components to check which part is contributing to the undesired behaviour.
    Altair Employee
    Please can you explain, how to plot energy balance curve for individual components..?
    Altair Employee
    Hi Shriram,
    From Analysis> select output block and choose comps from the selection menu and select all the parts, and thereby you can plot the time history for parts.
    Please view this video tutorial at https://www.youtube.com/watch?v=Ef7Spn-j7fA&index=6&list=PL1u26y75SCrA_BOCLaSewVCNY7xRvCTnA where all these steps are shown.
