🎉Community Raffle - Win $25
Join and Win
I have been performing dynamic analysis in Radioss on Fsae chassis. I'm getting " Radioss block running" error.
User: "saurabh  kapure"
Altair Community Member
Updated by saurabh kapure
1 - 4 of 41
    User: "PaulAltair"
    Altair Employee
    Accepted Answer
    Updated by PaulAltair
    the syntax in command line for the submission is -nt 4 this may be the cause? you have -nthread4 with no space, -both is redundant here since -both is default
    OP
    Thanks, it worked. But now I'm getting "initial penetration error". Can you please help me with that?
    I'm attaching the file.
    User: "PaulAltair"
    Altair Employee
    You have several areas in your mesh where the tubes are not correctly merged in the mesh (unequivalenced edges) such as below, that was causing a 0 gap condition in your contact (not allowed in type 7) I fixed in the attached and also reduced your gapmin to 0.75. I attached my version, it runs, but you should do your own checks and fixes (edges panel in HW)
    User: "PaulAltair"
    Altair Employee
    Letting the previous one run, I noticed you hadn't added anything to the rwall, so it just passes through, I added the 1st 50mm in here and moved the wall closer too, to get the structure in contact with it more quickly
