I have been performing dynamic analysis in Radioss on Fsae chassis. I'm getting " Radioss block running" error.
saurabh  kapure
saurabh kapure Altair Community Member
edited February 2022 in Community Q&A
Welcome!
Best Answer
  • PaulAltair
    PaulAltair
    Altair Employee
    edited February 2022 Answer ✓
    the syntax in command line for the submission is -nt 4 this may be the cause? you have -nthread4 with no space, -both is redundant here since -both is default
Answers
  • PaulAltair
    PaulAltair
    Altair Employee
  • saurabh  kapure
    Thanks, it worked. But now I'm getting "initial penetration error". Can you please help me with that?
    I'm attaching the file.
  • PaulAltair
    PaulAltair
    Altair Employee
    You have several areas in your mesh where the tubes are not correctly merged in the mesh (unequivalenced edges) such as below, that was causing a 0 gap condition in your contact (not allowed in type 7) I fixed in the attached and also reduced your gapmin to 0.75. I attached my version, it runs, but you should do your own checks and fixes (edges panel in HW)
  • PaulAltair
    PaulAltair
    Altair Employee
    Letting the previous one run, I noticed you hadn't added anything to the rwall, so it just passes through, I added the 1st 50mm in here and moved the wall closer too, to get the structure in contact with it more quickly
Welcome!
Welcome!
