🎉Community Raffle - Win $25
Join and Win
JSON and MQTT configuration in Embed
User: "Jeff_wu"
Altair Community Member
Updated by Jeff_wu
In NEW platform, I want to configure JSON and MQTT. How can I find those key parameters in the NEW SmartWorks and fill them in Embed?
1 - 2 of 21
    User: "Ragini"
    Altair Employee
    Updated by Ragini
    Hi Robbert,
    You can find the details to be filled in Embed MQTT Block in Smartworks site as below:
    For hostname: mqtt.swx.altairone.com
    Username and Password has to be filled from Things -> Interfaces field:
    You can retrieve Topic from Things->Details field->href:
    And use it as below (Remove "/" before spaces and append "/data" at the end of href):
    spaces/smartwork/categories/mqtt/things/01GKPF0SX8JKAFVFDNCA42PVGS/data
    For subscription, you need to use the same credential.
    For your reference, attached is an image of Embed MQTT Publish block updated with correct details:
    User: "Ragini"
    Altair Employee
    Accepted Answer
    Updated by Ragini
    Hi Robbert,
    I am attaching an Embed example as well for your reference.
    In this example, Smartworks broker is being used to echo the data
    The broker is:mqtt.swx.altairone.com
    You need to have an account in Altair Smartworks site:
         https://idp.swx.altairone.com/auth/registration
    Create a device.
    In Embed, place an MQTT Publish and Subscribe block in a diagram and configure as below:
    HostName: mqtt.swx.altairone.com
    Topic: <The topic you have created in your Smartcore portal. You can retrieve Topic from Things->Details field->href:
    Eg: spaces/smartwork/categories/mqtt/things/01GKPF0SX8JKAFVFDNCA42PVGS/data >
    Username: <The account username attached to your device. Eg: Embed@smartwork >
    Password: <The password for your account>
