🎉Community Raffle - Win $25
Join and Win
No restart file
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
8 errors written but not written what are the errors in RADIOSS. is there anyone who faced this issue?
Error is No restart file.
1 - 23 of 231
    Altair Employee
    OP
    Hi,
    In the folder please search for file_name_0000.out file which will list the errors n the model.
    Please share the same.
    User: "proudbrown"
    Altair Community Member
    Updated by proudbrown
    Hi,
    I am new to RADIOSS.
    I tried to run the solver but got error of 'no restart file'.
    how do i solve this?
    thanks!
    Altair Employee
    OP
    Hi,
    Due to some modelling error RADIOSS was not able to create the restart file for this run.
    Please check the starter out (_0000.out) file which will list the error. If you can share the starter out file we can help you to solve this.
    User: "proudbrown"
    User: "proudbrown"
    User: "proudbrown"
    Hi,
    Please reattach the file. Not able to download from the above link.
    Altair Employee
    OP
    Hi,
    This seems like an error in header card defined in the model.
    From Analysis>>Control cards>> select headercard and keep the values to 1 as shown below and try running.
    If the issue still persist please share the model file.
    User: "proudbrown"
    thanks!
    i'll try it.
    Altair Employee
    OP
    Hi I'm Syafiq,
    I just started using radioss, but I have the same issue which is no restart file.
    Can someone help me with this? Your help is much appreciated.
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi Syafiq,
    your model is unable to run because of the error:
    ERROR ID :         1109
    ** ERROR IN TH
    DESCRIPTION :
       -- THGROUP ID : 1
       -- THGROUP TITLE : RAIL
       NO TH VARIABLE DEFINED
    There is no variable defined for output request. The default output requests are defined by entering DEF in the Data: Var table.
    Altair Employee
    OP
    Thank you sir Ivan, I'll try
    Altair Employee
    OP
    Hi beloved members,
    I'm still new here, and i just started using HyperCrash, and i'm trying the bumper crash analysis tutorial, but it fails to run the simulation for there's too many errors. Can somebody help me with this? I have no idea on how to read and solve the errors. Your help is much appreciated.
    Thank you.
    Hi,
    Use Tools>Model Checker>RadiossBlock to find modeling errors.
    https://insider.altairhyperworks.com/wp-content/uploads/2017/09/T-T-1248-HyperMesh-Model-Checker.pdf
    Components 1-7 were not assigned Part card image, material and property. No simulation controls were defined (run time, output frequency and requests)- those can be quickly set up with Utility>Engine File Assistant. https://altairuniversity.com/wp-content/uploads/2017/05/EngineFileAssistant.pdf
    Altair Employee
    OP
    Thank you so much sir Ivan. You are my hero. <3
    Altair Employee
    OP
    Hi sir Ivan,
    I really need your help, i'm trying to run a modal analysis on a disk brake, but there are some errors that I couldn't understand.
    Thank you so much.
    Hi,
    both models have the same issue:
      *** ERROR # 2023 ***
      ADAMS MNF file creation requires DTI,UNITS card.
    You need to add DTI UNITS card. Go to Control cards>DTI_UNITS> input the same unit system which you have used for modeling and run the analysis.
    Altair Employee
    OP
    Thank you so much sir. Much appreciated <3
    Altair Employee
    OP
    Hi sir Ivan,
    Sorry to bother you, I've so much error that I couldn't understand, I really need your help.
    The error above has been solved, but there are still some errors when I'm triying to run the analysis.
    Your help is much appreciated. Thank you so much.
    Glad to help.
    *** See next message about line 10802 from file:
         C:/Users/Hicom/Desktop/modal 2/test 3/test 1/test 2
      'CTRIA3     10242       0   10725    1967    1968'
     This line was interpreted as:
     10802:CTRIA3, 10242, 0, 10725, 1967, 1968
     *** ERROR # 1000 *** in the input data:
     Incorrect data in field # 3.
      Expected INT > 0 or blank, found  INTEGER (0).
    the '0' in the 3rd column of the CTRIA3 definition indicates that at least some elements have no PIDs (property) assigned. Please check in HM if you have correct references from the comps (or elements) to the props.
    You have in HM two possibilities to reference the proper property to your CTRIA3 elements:
    1) (recommended): Assign the property collector (PSHELL) to the component collector your CTRIA3 elements are in
    2) Assign the property collector (PSHELL) directly to your CTRIA3 elements.
    Use Tools>Model Checker>Optistruct to find modeling errors.
    Altair Employee
    OP
    Hi sir Ivan,
    I've run the model checker, and it says no error, but I still can't run the analysis.
    I think I messed up my model, can you please check my model?
    Sorry to bother you so much & thanks a lot sir.
    There is a warning due to material properties:
    *** WARNING # 1030
     Consistency requirement E=2G(1+NU) violated (by 18%).
     Different values of G (either provided or inferred depending on element type)
     will be used. See the Material Property Checks section of the documentation.
    There are many errors due to bad element quality:
     Element # 6859, element type QUAD4.
     WARNING - Outside of recommended range: Vertex Angle =    174.48
               upper limit =    165.00
    I could remesh the model, but you would not learn how to do it yourself if I did it for you. I just corrected the worst elements so the model is able to run. You should remesh the model  using the these tools:
    • Geom>autocleanup to clean up the geometry
    • 2D>automesh>QI  optimize (F12) to mesh using quality criteria
    • 2D>elem cleanup
    • 2D>qualityindex
    • tool>check elems>2D (F10) to check elements
    There are some great learning materials from Altair university- Practical Aspects of Finite Element Simulation is a good starting point.
    https://altairuniversity.com/free-ebooks-2/
    Check the following Youtube channels:
    Altair University
    Altair India Student Contest
    ELEATION By Apoorv Bapat
    Altair Employee
    OP
    Thank you so much sir,
    I'll try my best to learn and do it myself,
    Thanks again sir, hope you have a beautiful day today.
    User: "Sohrab"
    Updated by Sohrab
    Hi,
    Hi,
    Thanks a lot for sharing this info. but I cannot find where this headcard is.
    is it in ENG_RUN ? I could not find it in the Analysis -> control card. when I go to control cards there are only options to choose to what to run.
    I would appreciate if you could lead me to these options since I am not able to see any result from my run as well.
