🎉Community Raffle - Win $25
Join and Win
Internal Programming Error #237
I have am getting this error when I try to run a very simple analysis containing just a single force on a composite part.
*** INTERNAL PROGRAMMING ERROR ***
in file "automset.F", at location # 237.
ioerr(1) = 0
**** ABORTING RUN DUE TO AN INTERNAL ERROR ****
How can I solve this ?
1 - 2 of 21
    User: "RobHoglund"
    Altair Employee
    Updated by RobHoglund
    Hi Ram,
    Sharing any output files will help understand the issue.
    If you just apply a single force as a boundary condition, you'd see an error without any constraints (SPC) defined in a static load case.
    Thanks,
    Rob H.
    User: "Ram Dhiwakar Seetharaman_21015"
    Altair Community Member
    OP
    Updated by Ram Dhiwakar Seetharaman_21015
    Hi Robert, thanks for your response. There was a SPC definition in the model. I ran it in another system and it worked, so seems like an installation issue. I will reinstall it and update you.
