I have am getting this error when I try to run a very simple analysis containing just a single force on a composite part.
*** INTERNAL PROGRAMMING ERROR ***
in file "automset.F", at location # 237.
ioerr(1) = 0
**** ABORTING RUN DUE TO AN INTERNAL ERROR ****
How can I solve this ?
Hi Ram,
Sharing any output files will help understand the issue.
If you just apply a single force as a boundary condition, you'd see an error without any constraints (SPC) defined in a static load case.
Thanks,
Rob H.
