How to turn on and off of Node or Element labels in HyperWorks 2020.1?
Hi Paul,
Are you speaking about Node and Elements IDs?
If it's the case, you still need to use Numbers functionnality in Panels as in Hyperworks desktop.
You can access the function by searching it in the toolbar : CTRL+F ==> Numbers
Thanks and Regards
Julien
If this is HWx2020.1 you might find it also in here:
Also under Preferences>>Appearance.
Hi Paul,
Thanks and Regards
Julien
