🎉Community Raffle - Win $25
Join and Win
How to equivilence two surfaces by only changing one surface?
User: "Jacobier_20601"
Altair Community Member
Updated by Jacobier_20601
I have three surfaces need to equivalence. Surface 2 and 3 have already well connected. When I tried to equivalence 1 and 2, the edge between 2 and 3 will b distorted. Is it any way to stitch edge between 1 and 2 by only changing surface 1?
1 - 3 of 31
    User: "Ben Buchanan"
    Altair Employee
    Updated by Ben Buchanan
    In the stitch tool you can drag edge 1 to edge 2/3.
    OP
    Those 1 2 and 3 are surfaces. I am not trying to merge edges. In fact. I generate surface 1 by using the upper edge of surface 2 and a line. Why generated surface 1 still shows red color edge?
    OP
    I think I figured out the issue. If I generate the surface in the the same component, it will genterate greenish edge. If I switch to other component but using the lines in the original component, it will yied red edge and sometimes it is unable to stitch it. Thank you all the same.
