Increasing the frequency of a waveform
reza hakimi_20486
reza hakimi_20486 Altair Community Member
edited August 2023 in Community Q&A
Hello
I have a signal (upper waveform), I want to reduce its frequency by 512 times so that the lower waveform is formed, how can I do this?
Answers
  • Rhonda_20369
    Rhonda_20369 New Altair Community Member
    edited August 2023
    Hi, Reza,
    This question is related to your algorithm design, not related to how to use PSIM. It would be more effective for you to discuss such questions with your colleagues.
    Your description of the question is "I want to reduce its frequency by 512 times".
    The simplest way is to use an up/down counter feeding to a comparator. Using the 1st signal as the clock input.
    You might have other considerations due to system control requirements.
Welcome!
Welcome!
