Segmentation fault error
All the Radioss Jobs (Running on 1 Node with 8 CPUs) are getting terminated with final status as “failed”.
Content of Error File :
/var/spool/PBS/mom_priv/jobs/29151.mgt.SC: line 165: 12748 Segmentation fault $starter_exe -np $cpus_np -nt $threads_nt -i $file_input
Exit Status Code in Output File :
FATAL:Starter error or errors detected in output file.Exited with status 139.
what could be the reason for the failure of the Jobs.
Thanks Rahul for your prompt reply /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
We are using .rad files for the computation.
And i cannot share the output files with you as of now.
Could you please provide some clue by looking at the exit code 139 and Segmentation fault error. Like what could be the possible reason for the failure.
Thanks /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
Could you share us Out file,system & update Information?
See attached screenshot.
Regards
Rahul R
