Segmentation fault error
All the Radioss Jobs (Running on 1 Node with 8 CPUs) are getting terminated with final status as “failed”.
Content of Error File :
/var/spool/PBS/mom_priv/jobs/29151.mgt.SC: line 165: 12748 Segmentation fault $starter_exe -np $cpus_np -nt $threads_nt -i $file_input
Exit Status Code in Output File :
FATAL:Starter error or errors detected in output file.Exited with status 139.
what could be the reason for the failure of the Jobs.
