Regarding the defect of the HyperView button in the Optistruct panel
User: "kei_22307"
New Altair Community Member
Updated by kei_22307
We are practicing the C-shaped clip of the tutorial to learn Optistruct.
The calculation itself with Optistruct is possible, but as shown in the figure, the 'HyperView' button is displayed in white and cannot be selected, and the result file cannot be displayed.
The software used is HyperWorks 2019 Student Edition.
I would appreciate if someone could teach me a solution.
Thank you.
1 - 2 of 21
    User: "PrasannaK"
    Altair Employee
    Updated by PrasannaK
    Hi Kei,
    I think you have already performed the analysis after solver deck setup and you are facing issue in viewing the results?
    After Analysis, result files are generated at the location where your solver deck is saved.
    To view the results (in HyperView) you can open HyperView and load the result file (usually .h3d file) as below:
    Open HyperWorks > Click on Client Selector > Select HyperView
    Once HyperView is opened you can you can load model and result file (usually .h3d)  > click 'Apply'
    Thank You
    User: "kei_22307"
    OP
    Thank You so much!
