Contact, optistruct
Hi
I have done this modeling in optistruct (an enforced displacement is applied to the back of plastic clip and required force for this this displacement is asked) but when I run the model and post process it in Hyper view I see the the clip penetrates in to the sheet metal. I think this penetration makes the results invalid. Would you please let me know what is wrong with this modeling. The model is attached
I have defined contact between all these surfaces but I don't understand why it behaves like this
1 - 9 of
91
Hi Bita,
I think this is because the leaf screen is way too soft and doesn't provide sufficient contact stiffness.
also, why the E value is negative for the leafscreen?
