Hello,
Which solver are you interested in? I am going to assume this will be solver dependent and relying on the type of output as well.
For example here is the help for Results at Position - Integration Points for Abaqus
thanks for help. I'm using optistruct as solver.
By default the stress will output at the element centroid. However you can request corner data and/or see the stress at the nodes (corner and mid).
What do you mean by integration points?
Here is the help for nodal averaging
https://help.altair.com/hwdesktop/hwx/topics/panels/nodal_averaging_elemental_results_hv_r.htm
You could also use the Linearization Tool
The integration points are exactly the points specified in the help documentation you sent. I got the correct answer with your helps and recommendations. Thanks
Hello,
https://help.altair.com/hwdesktop/hwx/topics/pre_processing/interfacing/hv_results_at_position_integration_points_r.htm?zoom_highlight=integration+points#ariaid-title9
