Hello everyone,
I have selected Hexa20 elements with 2order for my meshing and want to see the exact stress in Hyperview not only on the surface but also in integration points in elements. Does anyone know how this is possible?
Best regards
thanks for help. I'm using optistruct as solver.
You could also use the Linearization Tool
https://help.altair.com/hwdesktop/hwx/topics/panels/stress_linearization_hvx_r.htm?zoom_highlight=linearization
Which solver are you interested in? I am going to assume this will be solver dependent and relying on the type of output as well.
For example here is the help for Results at Position - Integration Points for Abaqus
https://help.altair.com/hwdesktop/hwx/topics/pre_processing/interfacing/hv_results_at_position_integration_points_r.htm?zoom_highlight=integration+points#ariaid-title9
Hello, Which solver are you interested in? I am going to assume this will be solver dependent and relying on the type of output as well. For example here is the help for Results at Position - Integration Points for Abaqus https://help.altair.com/hwdesktop/hwx/topics/pre_processing/interfacing/hv_results_at_position_integration_points_r.htm?zoom_highlight=integration+points#ariaid-title9
By default the stress will output at the element centroid. However you can request corner data and/or see the stress at the nodes (corner and mid).
What do you mean by integration points?
Here is the help for nodal averaging
https://help.altair.com/hwdesktop/hwx/topics/panels/nodal_averaging_elemental_results_hv_r.htm
By default the stress will output at the element centroid. However you can request corner data and/or see the stress at the nodes (corner and mid). What do you mean by integration points? Here is the help for nodal averaging https://help.altair.com/hwdesktop/hwx/topics/panels/nodal_averaging_elemental_results_hv_r.htm
The integration points are exactly the points specified in the help documentation you sent. I got the correct answer with your helps and recommendations. Thanks
