Altair RISE
Nominate Yourself Now!
Problems with Fatigue Analysis
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hey guys, I’m a mechanical engineer student and I participate in a project where I analysis the structure of a modern tricycle. I need help with the fatigue analysis. I make the training of fatigue by Altair and tried make the analysis, but I’m not sure of the results. I think the problem it’s on the TABFAT.
About the TABFAT:
               My analysis has 1D and 2D elements. I obtained the following values in the Linear Static Analysis:
Analysis 1D
Analysis 2D
σ_max
24,59 MPa
267,9 Mpa
σ_min
-19,71 MPa
0 MPa
               Can I represent the load cycle of my “vehicle” like a sinusoidal curve? Can you show me how I represent it?
              Should I represent these values for each of the fatigue analysis like one analysis for 1D elements and other analysis for 2D elements? Can I “mix” these values for the two analyses representing σ_max = 24,59 MPa and σ_min = -19,71 MPa?
               I think that a correct method is consider my load cycle like a variable load, but I don’t obtain experimental data.
About the MATFAT:
               I acquired the MATFAT data by the eFatigue website, but I don’t obtain the SE (standard error of log(N)). How I find out this? If I consider SE like “Default” (zero), how will affect my analysis?
Note: I’m making a SN analysis.
Thanks for helping!
1 - 20 of 201
    Altair Employee
    OP
    Hi @Thiago Marinho
    Sorry for a late reply,
    1. A sinusoidal curve can be represented by a constant amplitude fully reversed loading.
    This can be done using the TABFAT card, or can also be visualized using Utility Browser >> TABLE Create >> TABFAT,
    where time points and load points can be added.
    Both constant amplitude and a variable amplitude load history can be used (if variable amplitude, rain flow count is made internally  to convert to constant amplitude loads)
    1. The certainty of survival is based on the scatter on the Stress-life curve, which depends or modifies the SN curve based on SE (Standard error).
    When SE is non zero the reliability level can be considered using certainty of survival.
    1. The elements can be defined in the FATDEF, using the PTYPE entry.
    User: "Nachiket Kadu_22143"
    Altair Community Member
    Updated by Nachiket Kadu_22143
    About the TABFAT:
    Analysis 1D
    Analysis 2D
    σ_max
    24,59 MPa
    267,9 Mpa
    σ_min
    -19,71 MPa
    0 MPa
    About the MATFAT:
    Thanks for helping!
    Hi
    The stresses which you have mentioned under 2d what kind of stress you are talking about?? U are checking for von-mises or signed von-mises here??
    Altair Employee
    OP
    Nachiket Kadu .
    I'm making anything wrong?
    Altair Employee
    OP
    Prakash Pagadala
    Thanks for helping!
    Will I have a variable amplitude all right? Then if I represent in TABFAT like this (1.3395;2.679;1.3395;0) am I doing right?
    Does rainflow happens automatically? I understood that in this analysis the software will check that have a variable amplitude and will convert this automatically? Am I rigth?
    Nachiket Kadu .
    Linear static is ok! But when you r viewing results in hyperview, evaluating fatigue life using signed vonmises will be a correct approach. You can view signed von-mises for static analysis which will give u correct representation of max and min stresses.
    Prakash Pagadala
    Thanks for helping!
    Yes Rainflow approach calculates the min and max load automatically in optistruct when there is variable loading.
    Altair Employee
    OP
    Nachiket Kadu
    Yes, I'm using signed von mises when I'm viewing fatigue.
    About the Rainflow, the cycle that I represented in the last post is it correct?
    Thanks for helping bro!!
    Nachiket Kadu
    Rainflow will be applicable for random loading curve where crest and trough for the loading cycle is very difficult to determine, in such circumstances max and min is calculated using cycle counting technique which you can refer for better understanding. In your case if you are using a simple sine function, there max and min is already determined.
    Altair Employee
    OP
    Nachiket Kadu
    I'm sorry, I don't understood very well about the sine function. If I use a simple sine function, how I represent it ?
    Altair Employee
    OP
    hi guys
    I'm having a similar issue with my Fatigue Analysis
    Request your assistant to check my setup
    I have 2 problem
    1. Is my Loading Information is correct?
    Basically, I wanted to test 1 million cycles of alternating 823N force
    Have i defined it correctly
    2. I try to run it and end up error #6971 as in the picture. I don't have any clue where my mistakes are.
    Attached is the snapshots and my HM file
    Kindly assist
    Many thanks in advance
    <?xml version="1.0" encoding="UTF-8"?>WhatsApp Image 2018-05-21 at 23.59.10.jpeg
    <?xml version="1.0" encoding="UTF-8"?>WhatsApp Image 2018-05-21 at 23.59.33.jpeg
    <?xml version="1.0" encoding="UTF-8"?>WhatsApp Image 2018-05-21 at 23.59.49.jpeg
    <?xml version="1.0" encoding="UTF-8"?>WhatsApp Image 2018-05-22 at 00.00.09.jpeg
    <?xml version="1.0" encoding="UTF-8"?>WhatsApp Image 2018-05-22 at 00.00.57.jpeg
    <?xml version="1.0" encoding="UTF-8"?>WhatsApp Image 2018-05-22 at 00.02.36.jpeg
    Nachiket Kadu
    Just use the rainflow method. Its not an issue. For more detailed explanation for rainflow you may refer the theory behind it.
    Altair Employee
    OP
    Hi @yuri6996
    Looks like PFAT is missing in your model.
    Could you please check for the same?
    Altair Employee
    OP
    @Prakash Pagadala
    Thanks for your feedback
    May i know what is PFAT?
    I have been trained to use the Fatigue Process Manager to perform the fatigue analysis
    Just fill in the neccessary information and run
    Is the PFAT is a new feature
    I cant recall PFAT or FATDEF in HW14
    Thanks in advance
    Altair Employee
    OP
    @yuri6996
    Please see the image for fatigue process in OptiStruct 14.0
    Altair Employee
    OP
    Dear @Prakash Pagadala
    Will try to understand that parameter
    FYI
    I undergo training somewhere in 2013/2014
    Cant remember HW version
    Maybe 14 or much lower
    But I do remember that I didn't train using this parameter
    Its noted in my notebook to just use the fatigue Process Manager (FPM)
    Anyway many thanks for your kind assistant
    Altair Employee
    OP
    Below is the FATDEF card
    May i know which parameter should i enter
    Thanks in advance
    Altair Employee
    OP
    Hi,
    Check PTYPE and select the element type (PSHELL or PSOLID). For PID(#) select the relevant property and PFAT for PFATID(#)
    Altair Employee
    OP
    These 2 mouse clicks is the answer i am looking for this whole week
    Analysis completed and result superb
    Thanks @Prakash Pagadala
    Altair Employee
    OP
    :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
    User: "Md Ansari"
    Updated by Md Ansari
    Hi @Thiago Marinho
    Hi,
    I am trying to visualize cyclic fatigue of entire no of cycle in hyperview but  only life and damage i can see. help is appreciated.
    Thanks
