Initial Displacement in Flask
User: "GAJENDRA KUMAR NHAICHANIYA"
Altair Community Member
Updated by GAJENDRA KUMAR NHAICHANIYA
For shake of knowledge i tried to feed initial displacement for 10ms as imposed dis placement (T= 0, 0  Disp= 0,10). As below in given image.
What i expect - flask should oscillate about center axis. But in results what i found there is huge vibration in flask as shown in figure
Later on i tried with initial velocity (1cm/sec) also. but same happened.
Can anyone explained why it happened ?
here my unit assumption in (mm,kg,ms). Related .rad file and .h3d files are attached.
