Error#292 - Available working storage insufficient
Altair Forum User
Altair Forum User
Hi everyone,
I am currently running a pre-stressed modal analysis using Altair Optistruct. The first loadcase is a LGDISP non linear quasi static analysis and the second loadcase is a normal modes analysis which is PRETENS with loadcase#1.
The model comprises of friction, freeze and slide contacts, 2nd order tetrahedral elements, CBEAM elements and RBE2 elements.
Everything has been checked but something strange happens when I run it into Optistruct:
If I change the order of the tetrahedral elements from 2nd to 1st, I get the following error:
 OptiStruct error termination report printed to file
 'def_linear2.stat'.
 PROGRAM STOPPED DUE TO ERROR.
 NOTE # 1422
 There were 1 automatic memory expansion(s).
 (The result is not affected by this.)
 A fatal error has occurred during computations:
  *** ERROR # 292 ***
  Available working storage insufficient.
The strange thing is that if I run the 2nd order the simulation proceeds and starts as it should.
At first I corrected all RBE2 free-nodes and deleted any duplicate elements. Unfortunately, this keeps happening.
Please, I COULD USE some feedback asap.
If there is any need to share something, I would consider using file transfer. I am attaching the .out file.
Thank you in advance for your consideration.
Matteo
Welcome!
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited January 2019
    1. Try to force in-core solution using –core in.
    2. Disable dynamic memory allocation and set the total allowable static RAM using -fixlen.
    Before fixlen you can run the check to see what memory it allocates too.
    If possible try running in latest version OptiStruct 2018.0.1
  • Altair Forum User
    Altair Forum User
    edited January 2019
    Dear Rahul,
    Thank you for your kind reply. What is this error due to?
    A further update: I have seen that if I run only the non linear analysis part only, the analysis starts smoothly.
    So, apparently, only if I impose a pretensioned modal analysis, the error comes out.
    I have one question: how do I disable memory allocation? Do I have to use fixlen or is there another command I should type in?
  • Rahul Rajan_21763
    edited January 2019
    Working storage means the memory, not the disk space. For now, please allocate more memory with -minlen.
  • Altair Forum User
    Altair Forum User
    edited January 2019
    Dear Rahul
    Thank you for your reply. I have tried using fixlen some days ago and it worked! Thank you very much!
  • Rahul Rajan_21763
    edited January 2019
    Thanks for the update.
Welcome!
Welcome!
