Hi everyone,
What should i do to not get energy error except Gap_min in contacts ?
HI,
.The energy error percentage is the parameter that checks the energy conservation during each numerical cycle and it is computed by RADIOSS as a percentage.
If the error is negative, it means that some energy has been dissipated. Due to contact friction in a model energy dissipation will happen which will result in negative energy error in the model.
Please use the recommended contact parameters as below for Type 7 interface:
Istf=4
Igap=2
Fscale_Gap=0.8
INACTI=6
Gap_min=
Fric = 0.1
Iform=2
