I am trying optimize the cooling channels distribution in a cooling plate of a battery thermal management system using the Darcy flow analysis. The coolant is water and the flow is assumed to be laminar in nature. The inlet velocity/flow rate and the outlet pressure are provided as the inlet and outlet conditions. Heat flux is given as a boundary condition on the plate surface. I am not able to find any tutorials for the Darcy flow analysis and facing difficulties in setting up my model. Please support me by providing your insights on how to achieve the same. Thank You!
