Hello All,
I am currently running a non linear simulation that requires around 25hrs of computing time on a 16 cores machine.
It's got 300000 elements. Radioss adjust the timestep automatically and reduces to something around 4e-4s. I therefore need around 2500 time steps to converge.
The problem I am trying to solve is something similar to a beam in bending ( I do need non-linear) and my requirement is to find the static deformed shape (not a dynamic case, it will converge to a steady result).
I have tried explicit but timestep is 1e-9s and it would take 175days to converge...
Are there any tricks/ideas that could be used to speed up the convergence?
Thanks,
NR
Hi NR,
Please share the model file.
Use the dropbox link in the signature below to share the file.
